Just ordered a slitting saw arbor. Thought about making one but come on, too many projects already.
Every time I begin a new project I am reminded of what tools I no longer have!
Grrr.
Getting close to finishing this project. Soon i'll be able to use the rotary table.
Can't do much until I do the slit, I need parallel sides to facilitate a clean, parallel cut. Just need to do more profiling, slit the clamp, clean up edges and the surfaces.
It's gonna work just fine!
I decided not to wait for the cutter arbor.
I have a horizontal mill!
Mike Walton, aka Ulma Doc, donated it to me after the fire. It’s an Industrolite, from Oregon. 110v.
I have used it a few times.
I was able to mount this cutter. I think it will work if I take it easy.
Stay tuned.
Finished!
Works perfect. I just need to clean the table and reassemble with it’s new part.
Thanks to, Ulma Doc, I was able to use the slitting saw via my Industrolite Mill.
Thanks again Mike.
I’m learning it’s little quirks. I need to fix the auto feed. Shouldn’t take much.
