- Apr 30, 2012
- 2,401
feed rate changes are typed in as
G01 F10 (text goes in parentheses and G01 and F# alone on line normally )
once you set a speed it stays until you change it, there is no need for it on every line
G0 ( went to max speed)
G01 f5 ( now feed rate slower )
the G01 and F# normally are on the same line together then the move is placed under it
here is an example of moving down z cutting grooves...
X.4 (clears material)
z-2.0 (goes to grove location)
G01 F2 (sets slow plunge rate )
x.28 (plunges in groove )
G0 ( changes speed )
x.4 (retracts to safe distance )
z-2.2 (moves to next location in Z for groove )
z-2.4 (moves to next location in Z for groove )
I hope that helps
Steve
I hope that helps
Steve
