I just asked the speed because it gives an indication of the year it was made. 3000rpm is scary fast .I seldom use the 2000 rpm on my lathe and If I wish I could go higher through the vfd.Does your vfd not have an ability to use a brake resistor. It will be interesting to see a pic of the electro brake.
I must be the only guy to have a emco v13 that has a permanent gap. The lathes are beautiful but with this permanent gap the compound is about 100mm longer to compensate . So if you dont want your carriage to hang half way off the gap you need to screw the compound over .But this effects rigidity big time.
I am trying to find someone out there who also has a gap bed Emco.
In my humble opinion it must be the lowest point in Emcos history and there engineers should bow there heads in shame. Unless Im doing something silly.I will take a pic to show you what I mean.
