When you look at the shell mill shank. The end user doesn't typically change out cutting heads on the shank. we will have a shank for each head.
The manufacture doesn't have to build cutting heads in every shank configuration.
A 4" fly cutter will run in a 1/2" collet with no problem. On the other hand a 4" face mill would slip in a 1/2" collet.
Also, by extending the distance of the cutter from the quill bearings you are losing valuable head room, to say nothing about introducing more flex possibilities.
