- Aug 7, 2018
- 668
Hi Guys,
I agree with the above comments.
In general strip it down to the field windings, a good rinse in fresh water, then bake in a warm oven, until dry. Megger the windings to carcass. Then spray the windings with varnish. Re assemble, and test.
Depending upon the size of the motor the bearings might be PB, so carefully check the rotor for any rust on bearing surfaces. Ball races may or may not have water in them. If they are shielded the grease should have protected them, but they still might contain water. YMMV
