Hi guys and gals.
So I finally got my Chinese ZAY7045V/1 to the point where I can begin to try to mill something but I can't seem to be getting any results. I tried milling some mild steel, just to learn how things work. I had a 16 mm HSS endmill in a ER25 collet and tried to slot mill the steel. 0,2 mm depth of cut gave terrible vibrations at 500 rpm and kind of crappy finish. Anyway after lots of trying onething and learning something else and repeating several times I decided to test the runouts on the ER holder and the endmill, results were 0,05 mm runout on both which seemed reasonable since they are from China. But after that I stuck the dial indicator to the spindle and tried how much give it has when pushed and pulled and the result was 0,1 mm. How screwed am I, this seems too much, is there anything to fix this?
