- Sep 8, 2019
- 4,392
I spent 6 weeks building a very heavy fixture stand. The stand is over 5’ tall, & it has arms as long as 4’ that could have up to 125 pounds loaded at the end.
While I *do* have a height adjustable stand that takes most of the torsion off of the base, the large amount of weight at a distance of 4 feet would still act as a huge lever, so I’m going to bolt everything to the concrete.
I am also going to take this opportunity to mount the bench vise that I use for welding. I often weld things that are clamped in a bench vise, particularly with stick welding. I strike the arc on the vise and then move the arc to the workpiece.
I am going to use MIG for this project, as my TIG torch died while making the last arm on the fixture.
