On my Accusize-marked AXA set, the clocking is easier; just CCW rotate the ring and the gibs thread off the
bottom; then reengage them while CW rotating, on a different start of the drive screw, and
the clocking will generally be different. Just be sure both gibs engage at the same time,
you don't want one loose and the other tight. I also tried disassembly, but the
parts are apparently well fixed by some oriental clone of Henkel's threadlocker.
It's surprising the factory didn't deliver 'em clocked right.
The gibs, of course, won't thread off the bottom when the post is mounted; they'd run
into the compound.
