- May 4, 2015
- 3,583
I'm not sure turning it screwed on backwards is the best way . I think I'd use a face plate or four jaw chuck and indicate it in as close as possible . Any cuts not square and concentric will show up when machining it to fit the chuck . Just my thoughts , the material really doesn't matter when you cut it you'll know. Cast flakes , steel makes curls , cast steel will do both at times and be shiny . Don't use coolant on cast iron
