- Nov 5, 2016
- 1,417
Originally, I was considering putting an R8 on one of my chuck too, but decided against it. One currently has a short 1/2" straight shank. I like this better since it doesn't take much clearance to put it into a collet to use it. My Jacob's chuck has a R8 and I usually end up having to crank the knee way down to have enough room to put it into the spindle. The short 1/2" shank in the collet works great and holds well so I'm sticking with that.
I didn't have the wedges and didn't want to buy them so I decided to disassemble the chuck to push the arbor out. This also gave me the opportunity to clean it out good and re-grease the balls. The arbor popped right out with my arbor press.
If you make the two clamps mikey describes in his write up disassembly is pretty easy. The hard part is holding the pieces so you can unscrew them. With clamps made out of aluminum it's a piece of cake.
Ted
Ted
