2.2kW VFD Drive Inverter, 220V AC Single-Phase Variable Frequency Drive Inverter, Walfront VFD Speed Controller Inverter for 3-Phase Motor : Amazon.ca: Tools & Home Improvement
2.2kW VFD Drive Inverter, 220V AC Single-Phase Variable Frequency Drive Inverter, Walfront VFD Speed Controller Inverter for 3-Phase Motor : Amazon.ca: Tools & Home Improvementwww.amazon.ca
this VFD is what I have on my mill and lathe (2Hp 3 phase and 1 Hp 3 phase) so far so good
According to the installation documentation you can connect as an " AT2" configuration - and it mentions removing or not removing a run capacitor.....can be done but will require some further research/ proper settings
What is your speed control like now?
Lots of guys running the VFD have to pay attention to the loss of torque as you dial down the frequency. It is not the best to have a VFD on a variable speed machine and set it at one "pulley stop" and then speed control the rest of it. Many machines need the mechanical advantage created by the pulleys or gearing to give them the proper output power/torque. The VFD can then adjust the "in between"
Wow, amazon.ca over charges for that VFD It is ~$60USD on ebay
I am able to do 99% of my mill work on one pulley with adequate torque 25-120hz range
