- Dec 14, 2013
- 167
Nice looking lathe! Have fun with it.
dhidaka,
The part that you need to hold workpieces will probably look one of two ways. Most common is probably sometimes called a boring table. It will look like a wide flat cross slide with dove tail and gib on the bottom and one or two T-slots on top for clamping work pieces. Underneath, it will have a place to attach a cross feed nut. Or it will look like a face plate or the top of a rotary table and the bottom will fit your existing cross slide in place of the existing compound. Atlas made both types, although not many of them. I don't know whether Logan did or not. Maybe Globe made them for the Logan. To use different diameter cutters, it looks like you will need an assortment of bushings.
Also, if you use the gadget, you need to get a spindle nose thread protector.
If you are interested, there is a "Globe Milling Adapter" group in the Yahoo section that has a super selection of literature, pictures, etc. on the milling attachment. Globe also made cross slides like those in your pictures. What ever you do don't throw any of that stuff out. I suspect it has something to do with the Globe Milling Attachment.
Heres a link to the group. You must become a member of the group to view the stuff that is posted.
https://groups.yahoo.com/neo/groups/Globe_Milling_Adapter/conversations/messages
That's a pretty healthy attachment for a Logan 200 lathe! Want to sell it????
Here is an original brochure showing those attachments as options
http://vintagemachinery.org/pubs/2093/3386.pdf
