- Jan 29, 2017
- 311
Come to think of it, that looks like a magdrive pump. The motor doesn't have a shaft does it? In which case your impeller is magnetic and is driven by a magnet in the end of the motor. This does away with a mechanical seal and prevents potential leaks.
But it also means that the impeller position must be set to maximise efficiency and must be free enough to be spun by the magnet. Therefore there is very little clamping force by the nut and a teflon washer either side of the impeller would be better at minimising friction than a ss one.
