- May 13, 2019
- 1,016
Hi all,
I've been avoiding machining stainless steel after reading about how some grades are very difficult to work with and will work harden especially when using a (MicroMark 7X16) mini-lathe and (PM25) mill. But, I have a very simple project I need to be in stainless steel and thought this would be the time to try it.
I need to make some washers with these dimensions:
OD: 0.420" (10.67 mm)
ID: 0.257" (6.53 mm)
Thick: 0.035" (0.89 mm)
The original part is 316, but I bought both 316 and 303 stock. My thoughts are I would try 316 first and switch to 303 if I get into trouble.
So, my plan is to turn down the outside to 0.420" from 1/2" stock. Then, drill the 0.257" hole using a No. F drill. I'm not sure about using a spotting drill first since that seems to work harden the material. Then, finally part off the end to the required thickness.
Any thoughts or words of encouragement?
