The enclosure is 24x20x8 made by Yuco (?) found on Amazon. It isn't the highest quality, but it didn't break bank - came a horrible beige color, nothing two cans of protection enamel spray paint couldn't fix. Accidentally signed the front panel with a thumb print this morning as a small section is still curing.
The meters you see (I am also a sucker for instrumentation) are Volt meters, to measure the split phase and phase legs on the input, and the the 24VDC control voltage. I have though about measuring the current each driver is drawing with ammeters, I bought a Shurite Edgewise series meter to scope it out, and it requires a rectangular mounting hole (what a pain). Any good tips - wish there were rectangular knockout tools like the round ones I used on the holes. I also have fuse holders for the stepper drivers, not exactly sure on where the stepper driver ammeters and fuse holders are going to go.
The panel is a good size, and I know it looks like it was planned, but I feel like it is still too small. I've seen it written before, find the size you think you need, and add 4-6 inches on both sides - you'll almost never curse it being too big, but slightly small creates headaches. I think this enclosure will just barely work - I may need to come off with conduit to a small secondary box for stepper driver instrumentation, and eventually with a third box for the VFD/Spindle controls.
Slowly making progress, it will come in waves as I suspect these things often do.
-IM
