A positive rake tool would do much better, 303 does not tend to work harden to my experience, have made hundreds of pounds of chips with it; call it screw machine stainless. I use TPG inserts with it in 3/8 and 1/2 I.C. sizes in C-2 grade.
A 1/64" nose radius is rather large for such an unstable operation, try a .008" NR tool.Guys looking in my Shars catalog I see that the insert I am using is for medium finish on SS so I am going to order 424-1051 which is for finishing and has a 7* positive rake which has a nose radius of 1/64.So maybe this will help out some but I know I still need to take a bigger cut,well its to late for this part but I have 3 more that I would like to take a finish cut to where be easier to put little polish on them.If anything that I learn is having the right insert can make a big difference plus speed/feed so no more hand feeding for me
That is a positive rake insert.A positive rake tool would do much better, 303 does not tend to work harden to my experience, have made hundreds of pounds of chips with it; call it screw machine stainless. I use TPG inserts with it in 3/8 and 1/2 I.C. sizes in C-2 grade.
Sorry for not getting back sooner,I look for a name on it but found nothing.The tag that is seen on front just says Make In China with their symbol.Name may be on back side,when I take chuck off when start cleaning up lathe little bit I will see if names on back side.Off topic but what kind of chuck is that Kroll?
