Thanks, I feel a little less dumb. And the voice in my head when I started the cut, tangential tool holder/HHS, "Probably need to hone that tool."Without knowing any details, like tooling type, it's hard to guess. . . . Whenever I get this it's time to resharpen the HSS, or change the insert. It might be something else, but this most often fixes it for me.
Thanks, and yes I was using the TS with a live center.Are you using the tailstock for support?
If so you may wish to pull the tailstock half the error to you.
A slight nose radius on the tool would give a smoother finish in comparison to a pointed tool.
I'm not an experienced machinist, just a hobbyist. But whenever I see stuff like this 95% of the time, at least for me, it's the tool tip. Especially if the day before I had a nice finish on similar materials. If you try a piece of similar material with a short stick out (less than 2:1) and you get similar crap finish, there's a high likelihood the cutting tip has some damage. It doesn't take much damage to mess with finish. I've had poor finish on cutting tips that I can't see anything wrong at 10x, but replacing the cutting tip (or rehoning the HSS) fixes the finish problem. I use cheap inserts or HSS on most of my work. The cheap carbide TCGT can micro-fracture. I don't really care, at 33 cents per cutting edge, I just rotate the insert.Thanks, I feel a little less dumb. And the voice in my head when I started the cut, tangential tool holder/HHS, "Probably need to hone that tool."
Material is 1/2" O-1It is hard to guess without more info.
material being cut
Cutting tool
speeds and feeds
These are all very important.
From a distance, looking at the end of the cut it looks like you may have a large R nose on your cutting tool. Taking a very shallow cut with a large R nose will not give good results.
