In my line of work(Electronics, Electrician), we are more concerned with stock removal than fine finish. My comments will be biased in that direction. I had a supplier of "junque", recovered from the aircraft repair industry where I bought large quantities of "re-sharpened" files. Some were Nicholson, some were unmarked. They all cut well. The place is no longer, I had bought a "lifetime" supply when they were open. There are also smaller, 8" flat and 3 square and many "needle" files for modeling work. But those are for that one application on brass and "nickle-silver", a copper-nickle alloy. They very seldom see ferrous metals.
I do keep a "set" for soft metals, brass and aluminium. And another for ferrous metals. My favored file is a "half round", bastard, double cut, 10". I find the edge useful for working into corners. I find a marketed "set" to be a waste of time. My sets consist of 1-10" half round, 1-8 or 10" 3 square(triangle), and 1-8 or 10" rat-tail. The others are useful only for specialty applications. All of them are double cut.
There is one I presume to be specific to aircraft use, a 10" single cut, rasp, flat file. I use them on aluminium, plastic, and wood only. And one 10" half round that has been "cut down" to 6" length for my electrician's pouch. For "utility" use, it gets used on whatever needs doing in field work. And replaced when cutting is sorely slowed.
All of them are "carded"(cleaned). Usually when I think about it, not necessarily on a regular basis. All of them have handles, some store-boughten, some home made. Except for a couple, the rest are kept on a rack over my workbench. The "new" files are kept in a toolbox, wrapped in brown paper. None are oiled.
I realize the original question was regarding currently available files. My response was to indicate that rather than depend on "new" stock, I depend on old, resharpened files. My source has dried up, there are others of the same ilk. if you are finding the current crop to be unsatisfactory, might I suggest "recycled" industrial parts.
