- Jun 21, 2013
- 317
If a limit switch is hit during program execution, the program will stop, RESET(EmergencyStop) will be activated in Mach, and you will be able to jog off of the limit switch by Resetting Mach(take it out of E-Stop mode), "Limit Override" button(if Auto Limits Override is not selected), and using keyboard jog keys.
To resume the program, you will first need to make a note of where it was when it hit the E-Stop, edit the program so that it won;t hit the E-stop again, and then use "Run from Here".
