- Dec 29, 2012
- 394
The square opening around pin bearing? You don't need mill it.
You mean not to mill it but to drill? Or not to bother at all?
You removed material from piston diameter. Check if you need to remove material from rings groove too. (rings radial thickness need be smaller than groove depth)
Doctor Frankenstein , if the monster lives it won't know how to run. I've done lots of rebuilds using odd parts from different manufacturers....
