I agree. It's a hack. I just needed it asap and used it. It's probably 14 feet long each, so it became my choice. Once I got some other metal, I will switch them.Agree with RobertB above- probably not a good idea to use rebar as a structural element, seeing how it is made from (I believe) recycled steel and iron and most likely would be considered one of the lowest grades of steel available- I'd much rather see you use something a bit better. Also, test a few welds by cutting them open to check the penetration and strength.
M
I think you would be ahead of the problem by saving some money and possibly you life or others . And go to harbor freight with therefore coupon and buy there gantry crane around $700 . . It will fill all your needs and no accidents ,, I hope,, . Seems luck as been following you. I know it's a lot to spend but you think it's nothing if it's a mill or lathe. My point of view you get one life and one body. Pain sucks I live in it.
