- Feb 17, 2013
- 4,409
Good cautionary note. By the way, what you said is pretty much true no matter what (water based) solution you use. Any time you have dissimilar metals in contact with each other in water, there's bound to be some chemical action - ie, corrosion of one metal or the other. Aluminum with almost anything else will result in the aluminum being attacked ... and if it's a thin-walled container, it only takes a small depth of corrosion to eat through.One more note: aluminum containers aren't the best choice for soaking or storage. I use a lot of those disposable aluminum baking trays for part cleanup, project organization, whatever. Anyhow, I used one of the small loaf pans to soak a couple of pieces, covered the container when finished, and left it sitting on the floor a corner of my basement. Two weeks later I picked up the tray only to find it had eaten several holes in the tray bottom and had etched the concrete just a bit.
Hope your parts didn't get "high water marks" as the Evaporust leaked out.
