The VFD can be programmed to any range. My plan is to set the range to ±50%, from 30Hz–90Hz, so 0 on the dial gives 60Hz and the speed shown on the gear box.Hi
I love the speed adj, legend plate, the + & -, great job.
Does the 0 line up with the motors 60 Hz running speed, or 50 Hz. ???
If not can it be adjusted.
Jeff
That is a huge plug! Who makes that?
Looking good. Smart move to fasten everything to a back plate rather then trying to wire it up inside the bottom of an enclosure. Looks way more professional as well.
I generally prefer to use L6-30 twist lock plugs for everything. Not nearly as huge.
