that smaller bolt on your spindle is what I think holds in the cams. Try and unscrew it, then if you can get it out, spray penetrating fluid (kroil, PB blaster, whatever) down there. Then heat gun, then spray, then heat gun, then spray. You can also get something called Freeze Off, which also works well, contains a penetrating fluid too. After copious soaking for a while my usual approach is to heat/cool/heat/cool/use impact/ heat/ cool and so on. Heating and cooling sucks the penetrating fluid further in and also helps break down any rust or gunge.
