Another great modification that some do is to mount a winch on the arm to also be able to use it like a small crane.
AHhh... Before where there was darkness now there is light!No the chain is going inside the tube.
I just had it on the outside for layout to check the angle of the dangle at full extension and stroke, to be able to mark it.
The problem with that is the relatively small base is unstable. In order to stabilize the hoist, you would have to add a lot of weight to the base or add outriggers either of which would compromise the portability.Another great modification that some do is to mount a winch on the arm to also be able to use it like a small crane.
Yeah, down at the auction in AL there was a twin to this one, they had (3) 10"DIA, 6" thk pcs stacked on the back.The problem with that is the relatively small base is unstable. In order to stabilize the hoist, you would have to add a lot of weight to the base or add outriggers either of which would compromise the portability.
I believe that Franko made a modification to increase the stability.https://www.hobby-machinist.com/threads/potd-project-of-the-day-what-did-you-do-in-your-shop-today.14637/page-159#post-337555
Scary how around here we have the same ideas...Another great modification that some do is to mount a winch on the arm to also be able to use it like a small crane.
