- Dec 25, 2011
- 10,552
CORRECTION TO Post #7 above:
I'm also not certain as to what the top 2MT arbor is or who made it but it isn't an Atlas 945. My guess is that it was originally an Atlas M1-577 that someone shortened in order to use it with a 6" lathe, as it sorta looks like the one in the M6-945 kit.
The Atlas 945 kit is a set-screw type 1/2" shank diameter cutter holder set consisting of an arbor somewhat similar to the M1-577 (except that the taper is 3MT and the large diameter end is shorter), a 3/8"-16 draw bar and hand wheel, and a thrust bearing/spacer to support and center-up the hand wheel end of the draw bar. The 2MT version for the 618 and other 6" lathes is M6-945. The M1-577 and both of the other arbors directly take a 1/2" shank diameter milling cutter. There is an Atlas 563E 1/2" OD reducing bushing set with ID's of 7/16", 3/8", 5/16 and 1/4" for smaller shank diameter cutters.
NOTE: Never ever use a Weldon style (those with a flat ground on one side) milling cutter with any of the reducing bushings unless you carefully rotate the cutter so that its flat is on the other side of the bushing from the set screw.
