Chapter 6 Part 3:
So progress has been a tad bit slower, but I managed to finish up the mechanical assembly of the cross slide and tailstock.
The compound slide nut is an interesting design. By leaving a set screw loose, the nut is free to pivot and can self align to the leadscrew. After extending the compound slide to the rear, I tightened up this screw and it runs smoothly without binding.
Here is a shot of the mechanics behind the compound slide travel.
Begin Rant: Seriously who puts the two most used features of the compound slide (slide lock and rotation lock) ON TOP OF EACHOTHER? You have to pull out the slide lock to change the angle of the compound. That's going to need to be replaced with a set screw or something.
Correction, it became clear to me that I'm an idiot and the compound lock only blocks the rotation bolt when the compound slide is in one position and I can just slide it out of the way. Duh!
Final beauty shot of the finished compound slide.
Next I began work on the tailstock. This didn't take long as I did not fully disassemble it. The factory painted over several seams between the parts and I did not want to have to repaint. The slight rust stain on the nose of the tailstock and on the rear right bedway are the only two spots, and do not impair functionality. I'm pretty pleased with that.
The Enco version of this lathe does not have a graduated handwheel for the tailstock which limits it's usefulness in my mind. Grizzly's tailstock does come with the collar, but it might be a totally different design than mine. This part may need to be fabricated, but that wont be bad at all with a CNC 4th axis. All the locks were tightened up and the travel is very smooth. You can see my new keyless drill chuck from Shars in the picture.
I finally found where my two extra bolts went: the headstock cover hinges!
The rubber wipers were in great shape and I reattached them. The assembly is complete!
There are still a handful of things that need to be attached (The switch plate, a new rubber pad for the top of the headstock, tool post, etc.) but the mechanical assembly is complete for the most part.
The spindle is grossly out of alignment to the ways (wonder why that is
), so I'll need to tackle that soon!
In the next week or two keep an eye out for:
- Tooling and workholding
- Lifting the lathe onto the stand
- Spindle bearing run-in, belt adjustment, gear adjustment, etc.
- Electrical rebuild
- Bed leveling, spindle alignment, tailstock alignment
- Test cutting and more!
Until then, Cheers! - Mike
