- Sep 4, 2016
- 16
Making threads on the lathe in imperial or metric, takes a lot of time to innstall the right gears, is you have the right ones. I have the hole set of gears with my Emco Maximat 11 but never used them.
My experiance is to take the right tap or dies to do the job. Always a good cut and never the nurses with the thread Index on the lathe etc. With the fear to distroy your part.
Only if you have to cut more than 25 pieces or so it is wurth to setup the change gears. Ofcourse good quality taps and dies are expensive but also very precisely and you can use them over and over again.
Compare to costs, gears are not scheap the cuttingtool is not cheap specialy the inside ones.
