I'm going to attempt to adapt clough42's ELS to my PM1127. I figure I might as well do it publicly in case it ends up being useful for someone else. I have most of the parts now, and have the electronics and servo running on the bench. The first thing I decided to mess with is the rotary encoder. I needed a way to drive it from the spindle. I decided to try adapting one of the GT2 pulleys to replace a change gear. This allows a minimaly invasive connection.
The pulley is a bit thicker than the stock gears. This 80T has enough metal in the middle that I can turn out a shallower section in the middle if needed though.
It started out looking like this..
I held the protruding part on top in the chuck, cut the keyway (3/16 HSS blank worked great). Faced the bottom flat. Then gripped the end and parted it off. Then faced the parted side. Note that these are not a single piece. The center is solid, the toothed ring and the two flanges are pressed onto the center.
The spindle is 40 teeth, so the plan is to mate the pulley to an 80 tooth gear. Then use a 40 tooth pulley on the encoder. That should put the encoder at the same RPM as the spindle.
The gear will be held on the stock change gear rack with the stock axle. The encoder I'm planning on building a bracket to mount with t-nuts to the change gear rack where the second gear set would be.
