while I'm looking for another motor for a VFD on my Delta drillpress, decided to start the resto on the South Bend drill press I picked up months ago. it has an old 1/2hp Singer motor. I didn't know until I did some googling that a number of manufacturers used Singer motors on their equipment. when I turn the motor on, it buzzes, and I have to spin the motor pulley to get it going. runs quietly and smoothly until shut off. I don't know that much about electrical but from past experience that is usually an indication of a bad start capacitor.
I un-soldered the capacitor (attempted to discharge it first and got no reaction, which is a bad sign) and ran a test on it. got a big zero on the meter. other capacitors I've tested in the past have at least a low reading but never got zeros before. other capacitors I've checked have also had a range printed on them that the test meter should be in if they are good, this capacitor has no range data on it.
I also haven't had a capacitor before with a transistor (or maybe a fuse?) on it either, maybe that is skewing my reading. any ideas? hard to look for a replacement not nowing what range it needs to be in. thanks.
