To prevent chuck marks on your work try using .02~.03 brass shim stock. The chuck jaws will bite into the brass and the brass will hold the work well if you make sure to get the jaws tight enough. Never use paper, as you have discovered it simply does not work.
Jim C.
Jim C.
