So next up is the handles. These guys were in pretty tough shape. I started with aggressive wire wheel just to see where things were. From there the big handle had to start at 60 grit then 80 and 120. The others I was able to start at 150, then 240, 400 and 600 before moving to the buffer for a pass on the course wheel and then the two finishing wheels. It takes a fair amount of time and with two of the handles being so small it was a bit tedious. I needed to split my belts down to 3/8" which, fortunately, still tracked well on my sander. I kinda hate doing this process because it takes awhile and is tough on the back, but boy does it look good when you're done!
