I'll get some pics up tonight. Lathe is in place except now for power drop - that may necessitate movement. One of the leveling feet is stuck WAY down and I can't seem to budge it. I put some Kroil on it. (yes, I loosed the grub screw on the side) I need to root through my chuck wrench collection to see if I have one that fits those feet (or maybe TIG one up quick and dirty),
I decided to "honor" Memorial day by putting my Korean era veteran father/shop foreman to work. He sorted my tooling and took a good stab at my manual tap and die collection as well. He even cleaned up an old Park rotating table for my mill that I bought peeking out from a pile of chips one day at a yard sale.
We rolled the lathe in (still on her pallet) about 3 feet over from where we wanted it. Then raised it up 1/2" on jacks and demolished the pallet under it - SLOWLY lowering her onto 4 machine skates. Then we simply eased her over on the skates and popped them out 1 by 1. Lots of vacuuming as the pallet came apart by saw and the skates need perfectly smooth floor - but the good news is your cleanup is done when the job is done!
I did a second old Vidmar box because once you get the paint out you might as well do them all. I still need another coat on that box after I setup the drawers they way I want them. I will use Frog Lube on all the slides since it makes my tooling smell like Ben Gay. I'm going to cover the two boxes with a wooden top (already in my ample stockpile) and call it good late tonight or early tomorrow.
