So, I made some assumptions when buying tooling online. I assumed that all mills used 1/2 slots.
I was using/referencing the Harbor Freight manual for the 42976 drill mill even though my drill mill is a Homier. They are similar, but there are differences, like the drawbar and apparently the slots. The slots on my drill mill is 7/16", not 1/2"
So, now I am the owner of both 7/16" clamping set and a 1/2" clamping set. At least the steps are identical between the sets.
On a side note, I think I need to buy a second 7/16" clamping set.
(I still have to bolt the drill mill to the bench.)
Hardwarz,
That machine looks more robust than my X2 mill. If you have room, a coupling nut instead if the normal nut on your drawbar is better as after a few whacks, the mushroom makes it hard to fit a spanner whereas with a longer nut you can use the lower part until you need to grind it back. That fine feed looks like a good plan and if you get too much play, a gas strut to hold the head up is one idea. Regarding the clamping set, can't you mill down the tee nuts to fit your table or make/buy some and use all thread for the bolts. They do'nt have to be super strong in this table. I use coach bolts with ground down heads sometimes. Waiting for your 4 axis CNC conversion.
John.
I ended up buying a 7/16" clamping set. I thought I'd sell the 5/8" set, but I've actually been using it. The step blocks are the same milling, so holding a larger plate is easier.
