Step | Operation | Face | Tool | Rotary Table | DRO Display | Coordinates, inches | | |
| | | | degrees | Function | X | Y | Z |
| Notes: The following operations are executed on the rotary table in vertical position with the central axis aligned with the mill X axis. The rotary table should be adjusted so that it is square to the mill table to within 0.0005" over 5" travel, using shims if necessary. The 4" 3-jaw chuck is used as the workpiece clamping device. The flexible electrical contact datum point is assigned ABSolute 0,0,0 coordinates and located so that the X and Z coordinates will coincide with those of the workpiece (~8.65" above mill table and 4.75" from rotary table bed). The mill head should be set so there is 1.75 inches of clearance between the top of the head and the column retainer. Operating speed should be set at 1325 rpm. All tools excluding the 1/2" and 7/32" end mills and taps should be chucked in the Tru Center chuck adjusted for < 0.0002" runout. | | | | | | | |
1 | cut blank | | bandsaw | NA | NA | | | |
2 | weld blank to stub | | soldering iron | NA | NA | | | |
3 | level piece | | rotary table | 90/270 | NA | | | |
4 | face side of piece | | 1/2" end mill | NA | NA | As Req. | Variable | N/A |
5 | set DRO | | | | ABS | 0.4600 | N/A | N/A |
6 | 1st face | top | 1/2" end mill | 180 | ABS | 0.0000 | Variable | As Req. |
7 | set DRO | | | | INC | 0.0000 | N/A | 0.0000 |
8 | 1st face | bottom | 1/2" end mill | 0 | INC | 0.0000 | Variable | 0.0000 |
9 | measure top-bottom (XXXX) | | micrometer | | | | | |
10 | set DRO to -1/2 (XXXX) | | | | INC | 0.0000 | N/A | -.5(XXXX) |
11 | find top face, set DRO Y | | 1/2" edge finder | 90 | INC | 0.0000 | 0.0000 | As Req. |
12 | find bottom face, set center find on DRO Y axis | 1/2" edge finder | 90 | INC | 0.0000 | .5(YYYY) | As Req. | |
13 | set absolute coordinates at Z axis datum | | sharpened scribe | | ABS | 0.0000 | 0.0000 | 0.0000 |
14 | find top face, set DRO Z | | sharpened scribe, 50X microscope | 180 | INC | 0.1900 | 0.0000 | -.5(XXXX) |
15 | find bottom face, check DRO Z | | sharpened scribe, 50X microscope | 0 | INC | 0.1900 | 0.0000 | -.5(XXXX) |
16 | set DRO X,Y,Z | | | | SDM 199 | 0.0000 | 0.0000 | -.5(XXXX) |
17 | set backup SDM coordinates | | | | SDM 198 | 0.0000 | 0.0000 | -.5(XXXX) |
18 | set 2nd backup SDM coordinates | | | | SDM 100 | 0.0000 | 0.0000 | -.5(XXXX) |
19 | zero tool Z axis | | 1/2" end mill | | ABS | 0.0000 | 0.0000 | 0.0000 |
20 | final face | top | 1/2" end mill | 180 | SDM 199 | 0.0000 | Variable | -0.4500 |
21 | final face | bottom | 1/2" end mill | 0 | SDM 199 | 0.0000 | Variable | -0.4500 |
22 | face | SMA | 1/2" end mill | 270 | SDM 199 | 0.0000 | Variable | -0.4490 |
23 | face | insert | 1/2" end mill | 90 | SDM 199 | 0.0000 | Variable | -0.1928 |
24 | zero tool Z axis | | 0000 center drill | | ABS | 0.0000 | 0.0000 | 0.0000 |
25 | drill insert pilot | insert | 0000 center drill | 90 | SDM 199 | 0.0000 | 0.0000 | -0.0500 |
26 | drill bypass pilot | bottom | 0000 center drill | 0 | SDM 199 | 0.0000 | 0.0000 | -0.1600 |
27 | zero tool Z axis | | 0.1875 center drill | | ABS | 0.0000 | 0.0000 | 0.0000 |
28 | drill sample port pilot | top | 0.1875 center drill | 180 | SDM 199 | 0.0000 | 0.0000 | -0.1800 |
29 | drill SMA coupler pilot | SMA | 0.1875 center drill | 270 | SDM 199 | 0.0000 | 0.0000 | -0.0500 |
30 | zero tool Z axis | | 3.35mm carbide drill | | ABS | 0.0000 | 0.0000 | 0.0000 |
31 | drill bypass capillary bushing hole | bottom | 3.35mm carbide drill | 0 | SDM 199 | 0.0000 | 0.0000 | -0.2373 |
32 | zero tool Z axis | | 1.55mm drill | | ABS | 0.0000 | 0.0000 | 0.0000 |
33 | drill bypass capillary hole | bottom | 1.55mm drill | 0 | SDM 199 | 0.0000 | 0.0000 | -0.0550 |
34 | zero tool Z axis | | 0.042" carbide pc drill | | ABS | 0.0000 | 0.0000 | 0.0000 |
35 | drill clearance hole for 0.008" drill | bottom | 0.042" carbide pc drill | 0 | SDM 199 | 0.0000 | 0.0000 | -0.0250 |
36 | zero tool Z axis | | 0.020" carbide pc drill | | ABS | 0.0000 | 0.0000 | 0.0000 |
37 | drill large bypass passage | bottom | 0.020" carbide pc drill | 0 | SDM 199 | 0.0000 | 0.0000 | -0.0100 |
38 | zero tool Z axis | | 0.039" carbide pc drill | | ABS | 0.0000 | 0.0000 | 0.0000 |
39 | drill secondary pilot | top | 0.039" carbide pc drill | 180 | SDM 199 | 0.0000 | 0.0000 | -0.0500 |
40 | zero tool Z axis | | 7o taper tool | | ABS | 0.0000 | 0.0000 | 0.0000 |
41 | bore lower sample port | top | 7o taper tool | 180 | SDM 199 | 0.0000 | 0.0000 | -0.0600 |
42 | zero tool Z axis | | dual taper cone tool | | ABS | 0.0000 | 0.0000 | 0.0000 |
43 | bore upper sample port | top | dual taper cone tool | 180 | SDM 199 | 0.0000 | 0.0000 | -0.0500 |
44 | zero tool Z axis | | 0.008 micro drill | | ABS | 0.0000 | 0.0000 | 0.0000 |
45 | drill final passage | top | 0.008 micro drill | 180 | SDM 199 | 0.0000 | 0.0000 | 0.0030 |
46 | drill final passage | bottom | 0.008 micro drill | 0 | SDM 199 | 0.0000 | 0.0000 | 0.0030 |
47 | zero tool Z axis | | 120o c/sink | | ABS | 0.0000 | 0.0000 | 0.0000 |
48 | cut 120o bevel | SMA | 120o c/sink | 270 | SDM 199 | 0.0000 | 0.0000 | -0.0090 |
49 | cut 120o bevel | insert | 120o c/sink | 90 | SDM 199 | 0.0000 | 0.0000 | -0.0090 |
50 | zero tool Z axis | | 0.008 micro drill | | ABS | 0.0000 | 0.0000 | 0.0000 |
51 | drill optical passage | SMA | 0.008 micro drill | 270 | SDM 199 | 0.0000 | 0.0000 | 0.0160 |
52 | zero tool Z axis | | 0000 center drill | | ABS | 0.0000 | 0.0000 | 0.0000 |
53 | drill locating pin #1 pilot | insert | 0000 center drill | 90 | SDM 199 | 0.1200 | 0.3100 | -0.1256 |
54 | drill locating pin #2 pilot | insert | 0000 center drill | 90 | SDM 199 | -0.1200 | -0.3100 | -0.1256 |
55 | drill #2-56 fastener #1 pilot | insert | 0000 center drill | 90 | SDM 199 | -0.1000 | -0.1950 | -0.1070 |
56 | drill #2-56 fastener #2 pilot | insert | 0000 center drill | 90 | SDM 199 | -0.1000 | 0.1950 | -0.1070 |
57 | drill #2-56 fastener #3 pilot | insert | 0000 center drill | 90 | SDM 199 | 0.1000 | 0.1950 | -0.1070 |
58 | drill #2-56 fastener #4 pilot | insert | 0000 center drill | 90 | SDM 199 | 0.1000 | -0.1950 | -0.1070 |
59 | zero tool Z axis | | #51 drill | | ABS | 0.0000 | 0.0000 | 0.0000 |
60 | drill #2-56 fastener #1 hole | insert | #51 drill | 90 | SDM 199 | -0.1000 | -0.1950 | 0.1820 |
61 | drill #2-56 fastener #2 hole | insert | #51 drill | 90 | SDM 199 | -0.1000 | 0.1950 | 0.1820 |
62 | drill #2-56 fastener #3 hole | insert | #51 drill | 90 | SDM 199 | 0.1000 | 0.1950 | 0.1820 |
63 | drill #2-56 fastener #4 hole | insert | #51 drill | 90 | SDM 199 | 0.1000 | -0.1950 | 0.1820 |
64 | zero tool Z axis | | 1.55mm drill | | ABS | 0.0000 | 0.0000 | 0.0000 |
65 | drill locating pin hole #1 | insert | 1.55mm drill | 90 | SDM 199 | 0.1200 | 0.3100 | 0.0572 |
66 | drill locating pin hole #2 | insert | 1.55mm drill | 90 | SDM 199 | -0.1200 | -0.3100 | 0.0572 |
67 | zero tool Z axis | | 7/32 end mill | | ABS | 0.0000 | 0.0000 | 0.0000 |
68 | c/bore SMA connector hole | SMA | 7/32 end mill | 270 | SDM 199 | 0.0000 | 0.0000 | -0.1690 |
69 | tap #2-56 hole #1 | insert | #2-56 tap | 90 | SDM 199 | -0.1000 | -0.1950 | N/A |
70 | tap #2-56 hole #2 | insert | #2-56 tap | 90 | SDM 199 | -0.1000 | 0.1950 | N/A |
71 | tap #2-56 hole #3 | insert | #2-56 tap | 90 | SDM 199 | 0.1000 | 0.1950 | N/A |
72 | tap #2-56 hole #4 | insert | #2-56 tap | 90 | SDM 199 | 0.1000 | -0.1950 | N/A |
73 | tap SMA connector hole | SMA | 1/4-36 plug tap | 270 | SDM 199 | 0.0000 | 0.0000 | N/A |
74 | tap SMA connector hole | SMA | 1/4-36 bottoming tap | 270 | SDM 199 | 0.0000 | 0.0000 | N/A |
75 | zero tool Z axis | | 1/2" end mill | | ABS | 0.0000 | 0.0000 | 0.0000 |
76 | cut weld | SMA | 1/2" end mill | 270 | SDM 199 | As Req. | Variable | -0.4700 |
77 | cut weld | bottom | 1/2" end mill | 0 | SDM 199 | As Req. | Variable | -0.4700 |
78 | cut weld | insert | 1/2" end mill | 90 | SDM 199 | As Req. | Variable | -0.1950 |
79 | cut weld | top | 1/2" end mill | 180 | SDM 199 | As Req. | Variable | -0.4700 |
| Notes: the final operations are performed on the mill table using a conventional mill vise. The vise should be adjusted so that it is square and parallel to the mill table to within 0.0005" over 3" travel, using shims if necessary. The flexible electrical contact datum point is assigned ABSolute 0,0,0 coordinates and located so that the Y and Z coordinates will aproximately coincide with those of the workpiece. A buildup block should be used to bring the bottom workpiece support to 0.32 to 0.33" from the top of the vise jaws. This block can be milled in place to ensure parallel conditions for the workpiece. | | | | | | | |
1 | find top face, set DRO Y | | 1/2" edge finder | | INC | 0.0000 | 0.0000 | As Req. |
2 | set absolute coordinates at X, Y axis datum | | 1/2" edge finder | | ABS | 0.0000 | 0.0000 | 0.0000 |
3 | set absolute coordinates at Z axis datum | | 2mm pin | | ABS | 0.0000 | 0.0000 | 0.0000 |
4 | find buildup block floor, set DRO Z | | 2mm pin, feeler gauge | SDM 001 | NA | NA | 0.0000 | |
5 | find buildup block far surface, set DRO Y | | | | SDM 001 | NA | 0.0000 | As Req. |
6 | zero tool Z axis | | 1/2" end mill | | ABS | 0.2000 | 0.0000 | 0.0000 |
7 | clamp workpiece in vise, milled side down | | | | | | | |
8 | first face | back | 1/2" end mill | | SDM 199 | As Req. | Variable | -0.5800 |
9 | second face | back | 1/2" end mill | | SDM 199 | As Req. | Variable | -0.5200 |
10 | third face | back | 1/2" end mill | | SDM 199 | As Req. | Variable | -0.4600 |
11 | fourth face | back | 1/2" end mill | | SDM 199 | As Req. | Variable | -0.4000 |
12 | fifth face | back | 1/2" end mill | | SDM 199 | As Req. | Variable | -0.3600 |
13 | final face | back | 1/2" end mill | | SDM 199 | As Req. | Variable | -0.3571 |
14 | reverse workpiece in vise with sample port to fixed jaw | | | | | | | |
15 | final face | front | 1/2" end mill | | SDM 199 | As Req. | Variable | -0.3543 |
16 | drill mounting hole #1 through | front | 120o c/sink | | SDM 199 | 0.1990 | 0.1500 | through |
17 | drill mounting hole #2 through | front | 120o c/sink | | SDM 199 | 0.1990 | 0.7500 | through |
