My eyes are really feeling the strain of reading the tiny dials, so being the electronic gadget guy I am I thought I would add a DRO to the cross slide. Mounting it looks challenging. I haven't seen any pics using the A11 milling cross slide either. So questions:
1) Does the backside of the DRO bar have to be mounted? I would have to really build a bracket way out to support it and still have full length use of the slide.
2) Any suggestions on brackets to attach to the saddle? The rounded curves may look nice but FLAT is easy to attach...
3) Is attaching the bar to the slide and the sensor to the saddle preferred?
Fully advanced
Attached are my concept sketches for mounting full size glass scales to the Atlas lathe. I am cutting parts right now and should have it operational in a few days. The X-axis slide (15 CM travel) is mounted protruding behind the lathe on a "T" shaped bar bolted to the existing 3/8-16 holes on the carriage to get it out of the way. I incorporated a dovetail slide to ensure parallel travel, and include a push bar to move the readout head. I am concerned about the power feed on the X-axis forcing the glass slide past safe limits, so I will likely incorporate physical stops in the dovetail slide and use some sort of shear pin to prevent damage. The Z-axis is easier.
Fully retracted
