B
British Steel
Forum Guest
Register Today
I am the wrong person to answer that question. I don't have a BP, and I have not looked critically at many installations. A careful installation of any DRO, with additional protection added where needed, pays dividends long term. It is really important to keep the oil and swarf out of glass scales, and to not let them get bent or otherwise physically damaged. Hardware is usually included, but quite often it must be modified or new parts made to achieve an accurate, protective, and robust mounting.
I've fitted a few to Blidgepolts (Chinese ones), not that difficult but most of the supplied hardware went in the scrap for melting... it's important to ensure the scales are EXACTLY parallel to the movement, I run a dti gauge along the scale to check horizontally and vertically, aiming for zero to a few thou" divergence, with the dti mounted where the read head is going.
You will probably need to make adjustments so mounting on pads with grubscrews at their corners will give fine adjustment on castings with draft and allow fitting the scales more neatly than the supplied hardware (clunky cast ally angle brackets).
Leave the plastic shipping shim between scale and reader in place until you get to mounting and shimming the reader to ensure the right alignment and spacing. If you can, make removing the shim the last step (you may need to remove its retaining screws while you can get to them though, and tape it in place - bloody awkward!)
Dave H. (the other one)
