When you have a pulley mounted on a shaft with a key way. There should be two set screws. One directly over keyway to engage key to shaft. The other mostly is 90* from keyway. To lock pulley to shaft. If you put 180* from key it might want rock naturally because of the two pressure points. And red LocTite is always good insurance.
