- Apr 14, 2014
- 3,591
I would stick with using the tailstock for drilling. Even with a depth of only 1" I would peck drill the hole before reaming. As mentioned the walls of the part may be flexing. Overloading the drill flutes can contribute to less than smooth or oversize holes. Moving the tailstock by hand should give you the feel as to when the flutes are loading.
My personal preference for reamers are the spiral flute style. All styles work reasonably well, but the spiral flute style can better handle interruptions from slots and cross drilled holes.
I would do a couple practice pieces with all but 1/4" or less captured in the collet. Don't over tighten the collet to the point it will cause the wall of the tube to collapse slightly once the hole is drilled. Also be sure the tailstock is centered properly. I use an Edge Technology alignment bar like this to be sure:
I usually align mine to .0005". That's close enough for most operations.
Tailstock Alignment Bar 27-000
The Tailstock Alignment Bar by Edge Technology is used to align the tailstock to the headstock. Accurate alignment is critical to eliminate any taper in work pieces that are supported by the tail stock. Our Tailstock Alignment Bar makes the process of tailstock alignment fast, easy and accurate.
www.edgetechnologyproducts.com
