- Jul 22, 2019
- 33
I had a need to drill a 2" diameter hole in a piece of 1/8 inch thick steel. I tried a fly cutter that I rarely use. It worked OK in my drill press, but better in my mill-drill. I had to sharpen the bit, and straighten it, afterwards, but I got the hole done. The fly cutter had a 3/8" shank, was not really heavy duty.
My question is about drilling large holes in general. Is the fly cutter, crude though it is, the simplest way? I can see that it is limited in the depth that it can go, probably less than one inch. Large drill bits are expensive, especially when you only need to drill one hole one time. How about using a boring head? I do not own a boring head, yet. The boring head would permit a more exact dimension, but much of the time the exact size is not critical. Or is a boring head more to get a rough drilled hole exact?
Richard
Richard
