I;ve recently found that Relton's A-9 is even better than Tap Magic (aluminum) for drilling holes smaller than .040 in Aluminum. Tap Magic broke drills, A-9 doesn't. I'mnot sure that the same is true for larger drill/tap sizes.
How is the smell?
Oily, verses cinnamon.
I'd prefer the cinnamon, but using the Tap Magic after about 15 holes (.120 deep/through) one drill didn't clear and broke in the hole. Using the A-9 I drilled another 120 holes or so, Finished the run of clutches. Drilling .038 holels in 6061 T6 aluminum. 3000 rpm.
I like a castor oil base. Been using CRC TrueTap lately. I put it into squeeze bottles with a needle tip and a neodymium magnet inside the bottle to keep it in place at the machine. It's good for tapping and cutting and goes a long way.
(from mobile)
I use castor oil to make fuel for my RC model airplane engines. I never thought to try it as a cutting oil. It is cheap and plentiful.
