- Aug 29, 2013
- 1,050
Using a dog on larger drills to prevent rotation will stop the spinning in the Morse taper. It is also a good idea to check the drill tapers and tail stock socket for damage and the fit of the drill in the taper to see how good the fit is. A hardened Morse taper tool or bushing of good quality and in new condition can check the tapers using Permatex High Spot Blue for marking and scrapers for removing burs and high spots. It is a bit tedious and can take some time, but those tapers can be tested and repaired for solid seating and for concentricity with the quill. A Morse taper reamer can also be a good tool to use judiciously.
I have an SB 9C and a 9A. I often use a dog when drilling with a large diameter bit on the lathe.
My SB 9A was having some trouble holding on to a drill chuck. I had an MT2 reamer and that seemed to fix a lot of the problem.
