- May 7, 2023
- 2,360
The problem with putting the screws on the other side is it may/might/could tilt the head bit. If you look you can see two more "Fixing" screws above that one.I have a similar drill press from MSC so had to go look at it. On mine, the threaded hole is
about 1/4 inch higher than on yours. Gravity holds the head on and one would think that the
Allen screw is there to keep the head from rotating. I think it would be prudent to make a
threaded hole on the opposite side of the press a little higher up and then remove the screw
that has the crack so there is no pressure on the casting there. If there isn't a crack forming
above the hole, it's not a big concern. Then fill the hole with JB Weld and dab on a little paint
on that spot so you can't see it.
Also, I removed the Allen screw to see if it pins the head in a certain position going into a hole
in the pipe or something, but the screw just presses against the pipe to hold the head in place..
Whether this will ever matter is the questions that keep me up at night.
