- Mar 12, 2023
- 5
Hi everyone-
I have a Craftsman drill press that has a hairline crack in the casting where a screw thread is located. I assume this screw takes up the slop between the head and the column. There are two of these screws, and a roll pin that secures the head to the column. Would you repair this, or not worry about it? Are there any acceptable repairs other than disassembly and having the casting welded? I only have a mig welder with C25 gas, so I'm not going to risk ruining it. Could I drill and tap a new hole on the thicker, flat part of the casting between this hole and the other screw? Put a 1/2" u-bolt around the casting, replacing the thin flat plate on the u-bolt with something beefier that would be drilled and tapped for a set screw, then drill out the hole in the casting to make it a pass through hole? Ignore it? I have no idea how important this screw is to maintain drill press accuracy. Thank you!
