H
Hukshawn
Forum Guest
Register Today
I'm sure this topic has been beat to death previously, a quick search didn't return anything useful, however.
I have a 16N Jacobs drill chuck. Older. The jaws are decent, but definate signs of wear. I filed to remove burrs, etc.
Before I consider a rebuild kit, what is realistic for TIR?
I get different readings depending on how I clamp a drill, or end mill, or center drill. How deep I insert the piece, how hard I tighten, etc.
The most runout I read was nearly .017", which is just downright unacceptable to me, and I managed to get a 1/2" carbide endmill to run at .002". All depending on where the endmill sits in the jaws, how hard I clamp, etc. So the jaws are definitely worn.
I'm just hobby, but the weeble wobble bothers me. I tried running a reamer last week with less than desirable results. (Quite possibly also due to an old worn out reamer, but it wobbled none the less)
I know I've read several times before that it's nearly unheard of to have a drill chuck run dead nuts in a mill. So, how high should I really be setting the bar...? Before I go and spend over 100$ on a rebuild kit.
