- Jul 30, 2011
- 348
I've been a machinist, toolmaker, moldmaker for 24yrs.. I bought 2 import drill indexes about 20 years ago, I took one home, I left one at work in my box.. I still have both, sure a few of the smaller drills broke and also went missing, but I still have quite a few of those drills still left.. they were good quality taiwan made drills, not near as good usa made drills, but they worked fine for the money..
When I need cobalt at home, which is usually not often, maybe half a dozen times, I borrow one from work :huh:
depending what you plan on doing at home, I'm with the others, buy a decent set of hss bits, and just individual cobalt drills as you might need them..
You might even buy a couple extra cobalt bits when you get the hss drill set, the cobalt drills you might need at some point in time, such as #7 drill for tapping 1/4-20 holes, F for tapping 5/16-18, 5/16 used to tap 3/8-16, 27/64 for 1/2-13, also get the 1/32 clearance sizes for common bolt sizes such as 9/32, 11/32,13/32,17/32 the 17/32 will also be drill size for 5/8-11 tap..
let us know what you decide..
also, you might look around for auctions, that is the place to buy tooling..
