When geared correctly I can get 1500 rpm or so at the chuck on my old lathe , I might be able to get a lot more than that using the old drill press , if I turn up some better bigger & smaller pulleys for it .
Re:- The flexi drive getting hot , I was going to fill the outer sleeve of the flexi drive with a special high speed copper & silicone based light grease mixture to stop the over heating . The drive cable is rated at 6,000 rpm off a " wired in " Dremel .
I was hoping someone had actually measured the thread form & made one , for I don't have a tread gauge above a 12 mm thread . I do not have any UNF , BSF , UNC or Withworth etc . I can eventually work it out by trial & error but standing on the shoulders of giants is a way I'd like to proceed.
I was hoping to make a threaded nozzle that can be fixed up so the flexi lead retaining collar is fixed solid like it is on the Dremel when things are correctly attached. IE replicate the end of a dremel & have it all fitted to an anchored plate .
Lads .... Thanks for the heads up about the Parkhouse grinder with the flexi drive. I purchased one of their cheapie grindstone one end , belt sander the other end a few months ago .
I'm spending my dosh on other more needy ( says He ) things like ..... 52nd birthday presents for my lass ..... She's well into Bonsai and for years has used a cheap & nasty set of specialist Bonsai scissors & cutters . I've just spent £ 134 ( $ 180 USD approx . ) on a he top of the range set of Bonsai two scissors , a pair of long handled Bonsai branch snippers and pair of long handled bonsai wire cutters ( lovely tools to handle as well ) The pocket money has all gone till the next but one blue moon arrives .
I only want to turn the flexi drive to try and engrave 1.5 mm deep on soft metals such as aluminium , brass or copper plus the odd bit of mild steel , so I don't think I'll need the grindstones speed , torque or a massively strong flexi drive .
