- Feb 4, 2021
- 179
Understood, but I will only be holding endmills in there, and most, if not all of mine do not extend beyond the length of the collet.It appears the section of your drawbar between the handle and the collet is solid. T section of a drawbar is usually a hollow tube. That allows you to put a workpiece in the collet that's longer than the collet itself. The longer workpiece can extend into the drawbar tube, so only the portion that needs to be worked on extends over the bed.
Thanks,Having done something similar (not a drawbar, but requiring concentricity), if it were me and I stress, if it was me machining this, I would use an undersize drill to start the bore, then use a boring bar to bring the hole to size for threading (either using a tap or single point threading), then turn the diameters smallest to largest.
No tolerancesHave you given yourself a tolerance? say +/- 2 thou'?
3.5-inch of sickout seems like a lot to me, but I am a self taught rookie.The part is short enough that neither a steady rest nor a live center is needed .
I am making the draw tube as the one I have is ~0.740 the whole length. When I use it, I am instilling runout on the endmill. I am hoping to make a draw tube that allows for the collet socket to self center and not be interfered with by the draw tube. Might work, might not.I question what the purpose of the .490" diameter. Why not .740" all the way to the 1.5" diameter. Order of operations: face threaded end, drill, bore and thread the socket; turn .740" diameter up to 1.5" diameter.
No problem then. Reduce the diameter of that section as a last operation. Concentricity of that surface won't be critical. Or to preserve concentricity, you can turn that surface prior to parting and facing the 1/5" diameter end.No tolerances
