- Oct 18, 2016
- 2,852
In regard to determining the suitability of a particular QCTP to any given lathe, there is one critical dimension which is not usually specified. We get numbers for the swing over bed, swing over carriage, and center to center distance but not for the distance from the spindle axis to the top of the compound. It is this dimension which determines if a particular QCTP will work on the lathe. Unfortunately there appears to be no standard for this dimension among lathe manufacturers.
The minimum vertical setting for a tool holder is determined by the thickness of the tool seat and the size of the tool being used. For my AXA class QCTP, the thickness of the tool seat is between .410" and .471" depending upon the manufacturer of the tool holder. Add to that, a 1/2" tool, and my minimum tool height is .910" to .971". My Grizzly G0602 has a distance of .923" from the spindle axis to the top of the compound which means that the only tool holders which will allow me to properly set a 1/2" tool is the Shars 250- 01 XL with the .410 high tool seat.
As far as maximum usable tool height, that is determined by the difference between the height of the tool holder and the tool post, along with the minimum tool height. In my case, the maximum is well over the spindle axis and not of concern. However, if there is a greater distance between the axis and the compound, as in the case of the OP then
Shars gives dimensions for tool posts, as do Dorian, Aloris, and Phase II. A simple measure of the the spindle axis to top of compound distance should determine which QCTP and tool holders will work on your lathe.
For those individuals who are buying a QCTP along with a new lathe, it would be a useful contribution to this site to compile a list of lathes and their spindle axis to top of compound distances. I'll start off by offering the above-mentioned distance for the G0602 of .923" and .779" for my Atlas 6x18, Model No. 101.21400.
Finally, in regard to the OP's problem, I would simply put a spacer of appropriate thickness between the QCTP and the compound. On my G0602, would be able to raise the QCTP by 5/8".
RJ, I think your suggestion of compiling lathe dimensions is excellent. I'll start a thread
in Machine Accessories, since that's where the Tool Post Reviews are stickied. Perhaps
you could repost your lathe dimensions there and hopefully other people will join in.
