I was turning a part on my lathe using a collet and I was powerfeeding in the long direction. I had 6 inches of gap between the tool and the collet. Then the powerfeed stops and I hear clicking! Dammit! I didn't realize my carriage/apron ran out of travel and was hitting the the housing that holds the on/off lever shaft and switch!
I shut off the lathe and disengaged the feed. I moved it back and the feed seems to work. Did I damage anything or is there a powerfeed safety clutch that releases under overtorque? To be clear, it was the powerfeed, not the threading half-nut that was engaged.
Definitely a mistake I won't be making again.
Tony.
Tony.
